Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
Owner of this car heard of my work through other coworkers and reached out to me on getting his car ready for the show season this year. Was recently painted within the last year with a single stage paint job. That was news to him as he purchased the car after it was painted. After doing a test spot the pad came up red. Got out the ePTG and took measurements around the car. Was getting readings anywhere from high 400 to low 800 microns around the car. I would imagine there was a skim coat of bondo beneath to allow the body man to get the panels leveled and flat. Then covered with high build primer and blocked before laying down the red paint. Of course this is just speculation but I would imagine it the case as I haven't personally been able to lay down primer, color, and clear to anywhere near those high readings. The most I have laid down is a mid 300 range and that was with 3 coats primers, 3 coats color, and 4 of clear. The car was cut and buffed before I got to it as evidenced by sanding marks not completely removed in various isolated areas.
Armed with this information 100% correction was far from the goal as we wanted to leave as much paint on the surface while still getting it looking the way it should. Most of the sanding marks were reduced and almost eliminated. I erred on the side of caution and left some remnants behind as to not burn all the way through to the primer underneath. The car came out very well.
Compounded with XFE 15, Griots compound and polish, and finished off with Griots 3n1
