justin_murphy
- May 7, 2006
- 2,852
I went to mailbox last night to find me a little package. Jen (FloridaNative) sent me a sample of Optimum's new Poli-Seal to test and review. I've heard alot of nice things from this new chemical. Some are using it as a one-stepper since it has abrasives that remove light oxidation and light swirls. Some are using it after heavy polishing to remove marring and seal the paint in one step. This customer just wanted some protection for the upcoming winter. She wanted no compounding or no interior work done.......just a wash and sealant.
Here's the process and review....
Start Time and temperature:
9:00 am and 38 degrees
Finish Time and temperature:
11:00 am and 53 degrees
Payment:
125.00
Washed with Meguiar's NXT car wash
(Used wash ShMitt with a single bucket)
Optimum's Poli-Seal
(Used EDGE2K Green "experimental" pad at #5 setting)
First off, it smells great. Lightly banana scented. I took a small amount and rubbed through my finger. I didn't feel that many abbrasives but there were some. Using the EDGE green pad, I used medium pressure with slow overlapping passes. Pretty much just like if you were going to polish. I immediately saw water spots removed as well minor swirls. This vehicle was HEAVILY swirled so anything would be an improvement. As the Poli-Seal started haze, I raised up on the pressure and started some fast motions. I then removed the haze to reveal a super-slick, reflective finish. This porduct is my new one-stepper. I really was not that surprised with it's performance; I expected it with Optimum's successful products.
It really cleaned the paint......just look:
Other Products used:
Meguiar's Detailer Line APC
(4:1 for bugs and lower areas of the paint)
Meguiar's Detailer Line Super Degreaser
(4:1 for tires and wheel wells)
Meguiar's Detailer Line Wheel Brightner
(4:1 for wheels. Used Meguiar's Versa Wheel Brush.)
Armor All Extreme Shine Tire Foam
(Tires and wheel wells. Also used on running boards. Wiped down with damp MF mitt.)
Befores....
Payment:
125.00
Optimum's Poli-Seal
Befores....
