Eldorado2k
- Nov 9, 2015
- 14,545
- 645
I made a statement, based on what we all already know. That is, you can use less pads for polishing than for compounding, but less doesn't mean ONE.
Can you do it with ONE? I reckon.
For instance... are you going to use that pad that polished behind your wheels, at the bottom of your door, along your rocker panels, on your ROOF? You might clean it, but I'd not use it down low, then high as well. I'd do all the work up high, then take my 'used' pads and do the bumpers, down low, then rockers. One for the front bumper, one for each side, and I reckon one of those for the back bumper.
Hey, I decided to put this little debate to the test today on my own car. I didn't want to post it until I made sure everything was understood as fine between communication and stuff.. Basically I wanted to make sure this didn't come off the wrong way or offensive to anyone because that's not at all how it's intended to be, I just thought it'd be interesting to find out how it went in a real life situation, with a similar product to boot..
Meguars Black Wax AIO should be comparable enough to HD Speed AIO. The goal was 1 polishing pad, 6.5"on the G21, clean on the fly w/brush & terry towel by my side. I ran the polisher @ speed 4.5 the whole way though, normL/moderate pressure, worked every section a good long while. [I wasn't simply spreading wax, worked it more like you would a normL polish/compound across the whole car]
I had to clay the hood but all other panels were smooth after a waterless wash with D114.
Ok so here's what I'm working with. Pic just before I got started. Notice I only have 2 polishing pads available atm. The sealed 1 is brand new and unused.
Ready to begin.
Here's what the pad looks like after polishing half the hood & fender. [before cleaning on the fly]
And yes, since I had to stick to the plan, I used the same pad to polish under the belt line/rocker panels. No easy way out.
Clean on the fly, and proceed to the trunk.
Speed 4.5 non stop.
Black Wax doing it's thing..
Here's how the pad & terry towel looked halfway through the car.
Ok here's where things get interesting. The whole drivers side of my car is a re paint [prior to me owning the car] and I've never been able to truly polish this side of the car due to this paint simply being sort of crazy.. The 1 time I attempted to compound the scratches out they somehow began getting worse instead of better.. It's like I was revealing the hell below. But since it's Light Green Metalic paint [equivelent to metalic silver] most people can't usually see the horrible condition this side of the car is actually in.
It wasn't easy finding a good picture of this mess, but here I found an example on the drivers door. Keep these nasty scraches in mind to give you a real idea of the kind of pressure I was putting down in order to eventually fill these defects w/the Black Wax.
Worked this whole side with extra passion due to the nasty defects I was up against.
Wax applied.
Ok almost done.. Last panel, I left half the hood for last as I worked all the way around.
Here's the pad just before the final portion of the hood. It hasn't exploded, dissinegrated, burned up, or whatever it was supposed to be in danger of doing. Pfftt...
Ok, made it though without much of a sweat. 1 pad did every panel, including the rear mirrors, only part I skipped was the front bottom bumper. Is the pad toast? Yea it's definitely reached it's point.. But it made it!
According to the naysayers we should have a degraded final result on the right side of the hood afterwards. Due to all the dangers we just put 1 pad through
Remember the drivers door? This is how the whole right side of the car looked since the day I bought it.
After:
Same spot, after:
I had never thought of using an AIO to fill these defects and polish out this paint until now.. This side has never seen gloss quite like this until now. After using Megs Black Wax w/G21, Scratches are filled.
Car came out great, even with using just 1 pad on speed 4.5 moderate pressure, heavy defects on the whole right side of vehicle completely removed/filled.. As GSKR, Detailing by M, and myself easily predicted, it was a piece of cake.
1 pad. Good day. Thx for reading, good luck to OP on your 1st full detail.
