They're the same. My 4" pads are just the b&s flats. I prefer the cuts in the face though. They run cooler, and smoother.
Cool will include them in my next order.
So what is the final verdict of HD Speed? This product was recommended to me as a novice detailer doing his first correction on his weekend car (black Ford paint).
My goals is to CORRECT/REMOVE the light to moderate swirls that I have; not just fill them in for them to reappear in a couple of weeks. In that case, I would have bought CG Blacklight.
Direct from David Fermani (THE source for all things 3D HD).
"Speed do not fill in the sense of masking or hiding defects. What it does is add extra gloss due to the wax content in it. Speed is a combination of HD Polish & HD Poxy. "
However... he has also said that Poxy "fills". :dunno:
"Not only is Poxy fresh paint safe, it also does a wonderful job of filling/covering light haze and/or cobwebbing. Go for it!"
"Keep in mind that most waxes/sealants are oil based and most will fill by depositing oil on the surface. This oil fills in spider web marring considerably until it gets washed away or evaporates."
The above statements were quoted over in another forum, when he said it didn't have "fillers".
Then Ben@3D said"
"I believe what David was referring to here is that HD Poxy will hide some of those things a bit. However, HD Speed will correct those issues instead of hide them. An IPA wide down will reveal they are no longer there.
There is no chemical added to HD Speed or Poxy with the intent to hide. The chemicals used to provide protection may have slight filling effect as a biproduct but that is not why we use them."
All of the quoted text was/is on Autopia. There was a short, but SPIRITED discussion(1 from Ben) and the rest from David and Rasky (Chad). Chad was determined that SPEED, (and all polishes) by default 'fill'. Where it the statement made by the powers that be from 3D HD is that it in fact doesn't. At the end of the thread, even Thomas Dekany chimed in with his knowledge of the product (being as he once worked at 3D).![]()
This thread has been going on forever lol.
So Speed will correct swirls, and Poxy will fill in whatever I missed?![]()
On a side note....
I left Meguiar's back in June of 2009 to come to Autogeek but even 6 going on 7 years later I'm still the number one poster on that forum.
Members by post count
Not that post count matters....
You can never be replaced Mike![]()
