Absolutely. Even the "mixed hair" version is very soft.
the advantage of using that ^ brush is it's size (and bulk) so it will cover more area (quicker as well) and not flatten easily like a small/little brush would. use one head for cleaning the wheels and the other for dressing tires. so many different uses for that brush...
btw DFB, the pic in your avatar with the rock star is looking smooth :dblthumb2: the cars in the background look cool too... :laughing:
My two bark at the Postie as well, but she knows if she stops the electric buggy she can come over and pat them.
Have you been seeing some online ads for some new Australian detailing supplies places? I can't remember what they're called, but I've seen 2 or 3 in the last month, looks like generic rebranding to me.
You could recondition the rubbers like I do, if the rubber isn't actually damaged, you just need to remove the contamination.Had the Jaguar serviced yesterday. Of particular concern was a lack of AC performance, which is something that has occurred before. Last time, the system was inspected and found to be low on gas, but no leaks could be detected. This time, a leak was found, and a replacement pipe needed. This is a common problem on early build XE's, so I'm not surprised or concerned. The replacement part and fitment are a relatively cheap fix.
What's not a cheap fix, and something I politely declined, was the quote of $250 to replace the wiper blades. :wowwow:
Yeah, no thanks. Parts already ordered and I'll do that myself.
I'll understand if it takes a while to answer, I'm just seeing on the news that there are major power outages down your way. Hope you're safe down there.
Man, that Victa is the Mad Mulcher lol.
Looking at your fresh underbody on that little beast reminds me of what I did with my new mower before I started using it. I had some Adam's Polishes undercarriage spray in my garage and thought I'd try it on the mower underbody. The hope is that I'd get better mulching with thick healthy lawns. It worked pretty well. I gave it an initial spray and wiped off the excess. After that, I'd spray off the underbody at least once a month and re-apply. It was worth the effort and cost for a little better mulching and catching as well as easier cleaning.
