DG 105 the most durable *sealant*?
I think some might also suggest Klasse Twins, Zaino, FinishKare, Optimums Optiseal and Ultima too.
Do some sealants look better on light metallics than others?
As long as you polish the paint w/ something like m105/205, or clean it with something like Pinnacle paint cleansing lotion first, is it acceptable to use just Klasse high gloss sealant w/o using the Klasse AIO? Also what about using just the high gloss sealant on glass, plastic, or metal? any thoughts? (sorry to thread jack) but really curious.
105 is great but Collinite's 845 lasted a little longer for me.
Prep makes all the difference though in and LSP's longevity.
This will certainly work and likely well, I prefer personally to use the two Klasse products together however as they "seem" to link for a great durable basis. I cannot however suggest they include a bonding agent or something special in AIO that does this. Duragloss and Zaino both offer these products that bond/cure and are said to help with length of protection.
If you get the Klasse SG make sure you know how to apply it..... WOWO (literally)
I'm not concerned with waxes, just polymer sealants. :xyxthumbs:
If you'll be applying a new coat each month or so then use any sealant they all last at least that long. But if you want a sealant you can apply and let go for months without even topping it with another coat or a QD/spray wax then Autoglym Extra Gloss Protection,
Chemical Guys: M-Seal, Jetseal 109, Speed Amor , Klasse AIO and Sealant Glaze, Hi Temp Paste, Zaino AIO, Z2 and Z5 and Wolfgang Deep Gloss Sealant were all tested and found to last at least 6 months in a big sealant test. Of course it really depends on your environment and how you treat your paint, but I used a finalist wax from the wax test the same guy did and it has lasted all winter so far. I personally want to try WDGS because it won't stain trim and I'm getting tired of my NXT 2.0 leaving the hard to get off stains on my car. It's kind of hard to find a wax/sealant that won't stain.
If you are looking a sealant that is GREAT on trim and glass or plastic, get Ultima Paint Guard Protection Plus (UPGP). It is a great Wipe On Walk Away (WOWA). Dries clear and shiny. IME!
