Did Reload just screw up my coating??
Reload may have different hydrophobic properties than the coatings?
Edit: just talked the Corey. Beading of reload should be quite similar.
I've had different experiences with spray silica coatings: Reload, TAC Quartz Max, Polish Angel, TAC Moonlight, Gyeon Cure, and they do alter in my opinion the properties of the coating. It can be subtle and not-so-subtle. So do soaps. Shampoos like Reset may help eliminate the issue of polymers left behind by some soaps, but if they get rid of the spray coating, that'd be pretty disappointing. Using a shampoo that leaves nothing behind is what you should do for cars that are coated, but I have a feeling that even if it makes your sheeting improve, you'll have to wait it out. The coating will reveal itself in time.
(Sent via my mobile device...)
