I used CarPro DLux for the first time on a wheel (one wheel to test), front plastic grill, and side mirrors on my G35.
I need some help.
First, the product was quite difficult to remove, even with the suede. It was like trying to take off a dense compound. Is this your experience? Second, I let the product cure for 10-30 minutes in 90 degree and 90 pct humidity. Is this long enough? I applied again to a side mirror and let cure an hour and it was slightly easier to remove, but the same general idea. Maybe this is consistent with your experience, but I hadn't expected this and am worried that I did not apply correctly. Third, the surfaces do not feel slick to the touch, certainly not as slick as an LSP. Is that correct?
Perhaps this feel is what it is supposed to do to bond and for longevity. Is this your experience?
Thanks, David
I need some help.
Thanks, David
