How would I do that?Mark, just measure the current of both units and it will answer a lot of endless speculation.
If there was change, they could use same motor but just limit current draw to effectively slow it down.
Agreed. :dblthumb2:
Clear your PM's!!!
Here's griot's response to my email.....
Hello Mark,
Thank you for your email regarding our Random Orbital.
Both of these units are the same internally. The only difference is the sticker.
I would say that the reason one of the units is stronger is that the DIP switch was set to a higher and incorrect setting at the factory.
Mark if you have any further questions please feel free to contact me directly!
Thanks,
Kevin.
THOUGHTS??
I just emailed Griot's a link to this thread.
You need an ammeter. If you have an electrician friend they may have one.
Thanks Ski2,
I checked my father in laws GG6 that I bought him for Christmas, his does not say professional on it. It still is very powerful and rotates 5.5" pads on speed 4 with ease. I really can't notice any difference between my "professional" one and his non P version.
I think this has all came about by people wearing them out then demanding a warranty replacement. :nomore:
I still believe the GG6 is the strongest RO out there.:dunno:
I don't think you guys are imagining this, makes you wonder if there was a run batch that have an issue? Seems all the pro version were good on power and only some of the non pro are .... Hmm.It isn't just my imagination I assure you
My original unit was still working terrific untill I loaned it to someone and they dropped it
The Meguiars has as much if not more power IMO. Not to mention machine stroke.....
Nope, the pro lable just denotes a change in a build run. Maybe a bad batch or maybe the MFR made changes to build it cheaper for their profit and Griot has no idea.Do you think if I put a sticker that says "profesional" on the side it will make it perform better?
Thanks!!!With an ammeter (clamp tester) though, you will also need a line splitter to get a reading. A more practical solution for non-electricians would probably be to get a Kill-a-Watt or similar consumer-targeted device; these are widely available online (Amazon, for instance) for around $20.00. The Kill-a-Watt plugs into the wall socket; the Griot is then plugged into the device. This will then provide an accurate watts-consumed reading in real time as you use the polisher. Turn on the GG6, turn the speed up all the way, and simulate a heavy mechanical load while watching the digital readout.
Here is the response I recieved from my contact at GG:
In regards to your question about our latest generation of orbital, it is lighter then the previous generation but does in fact have more torque. Our orbitals are not industrial strength machines and cannot handle 10-12 hours of continuous use.
Many detailers use our machines in this way (all day, everyday) and then say our orbitals are defective or do not work after a year or two of use.
The orbitals are designed for a hobbyist or the weekend car guy who has a few vehicles to regularly polish and wax, it's not designed for industrial use and that is why we no longer have the word "Professional" on our orbital. In no way have we lowered the quality or power of our latest generation orbital.
Our lifetime warranty covers manufacturer defect, we do not warranty wear and tear. So if the orbital unexpectedly stops working we will refund, repair or replace the machine. If the orbital stops working due to being dropped, abused, run-over, etc. we will not warranty it."
Hope this helps!!
Once I measure the wattage between the two units I have, then the mystery will be solved, at least for me.Mystery solved...
Once I measure the wattage between the two units I have, then the mystery will be solved, at least for me.![]()
:laughing:Until then,
Seriously Mark, when you get it all figured out at the end of the day you still have options to help you tackle whatever it is you're working on.
And dang man, talk about starting a fire and then stoking it... you're the best, in fact ZEE BEST!!!!!!
Check out the number of replies and views!
