Badlilstang
- Mar 12, 2014
- 82
I try to do my detailing in the AM which is hard to do with a gas powered unit. I wake up the neighbors. I am also tired of dealing with fuel and oil changes etc. I use an MTM Foam cannon and I have looked at a few models of Electric pressure washers. Please advise.. trying to stay below 300$. I realize it won't foam as well as my gas powered one but will still get some foam out of it.
I also read there are high pressure and low pressure MTM foam canons.. I saw a test of both on an 1800 psi 1.4gpm pressure washer. The Low pressure MTM Foam canon foamed MUCH better. Is there a way to confrim what model I have?
A few models I was looking at...
Sun Joe SPX3000 - Great reviews and specs are nice but measured output low?
AR Clean 383 - Good reviews, leaks but can be fixed, no quick disconnect setup
Green Works 1700-PSI 1.4-GPM - Lower specs but I have seen it recommended.
Karcher X Series 2000 - Mixed reviews on this one I have read.
