It's true, yes you can do it and very easy at that.
There are videos to show you how to do it but really isn't hard.
WW's has become very popular and for good reason.
Just follow the directions on the bottle and you'll be fine
In most cases I can wash my car in 20 minutes without having to drag out a hose amd buckets.
Give it a tey and see what all the fuss is about.
What kind of car do u have?
I have a ram crew 1500 and doing either a rinsless/ washless or a regular 2 bucket takes me 1.5 to 2 hrs to just wash and dry
I agree. I always rinse the vehicle and drive it in into the garage. When weather is good, I prefer to bucket wash wheels and wells. I always presoak with a WW and then use a rinseless. UWW+ does both jobs very well and is by far the least expensive at about $3.50 q a gallon for WW strength. ONR is a better deal for rinseless.I did not like the DP WW. Pinnacle, UWW+, and BF are all much better. Not to mention the first two are much more cost effective due to much higher dilutions. I'm convinced if you maintain your car only by waterless washes you will cause more marring quicker than using other methods that use more water or a pre-rinse. This will be especially noticeable on a dark/black car. I'm sorry, but that's just the facts. If your not concerned about marring and just want clean and shiny, than go for it.
The best/safest method will always be pre-rinsing the car to remove loose dirt before touching it. You can use a pre-rinse in conjunction with a waterless method. It works quite well and is fairly safe on harder paints.
I too always wash the wells and tires before a WW, maybe I need to rinse the car off too:dblthumb2:
09' RAV.
I can wash with using two buckets and hose less than an hour, keep I mind most of the time my car is pretty clean.
So your saying it takes you two hours for a WW and dry?
Im going to order one of the brands you guys talk about...:xyxthumbs:Im the MAN
Just a few more questions,
1. How many washes will I get out of a bottle of waterless and rinseless? I have a F150 4door.
2. Is there any part of the truck I should not use waterless/rinseless wash besides tires & wheels? Ex. clear plastic lens
3. Is pre-soak just term for wetting the truck, or is it a product to buy?
Thanks for all the help.
