Electric Pressure Washer
Cyberdan3
I have done a lot of reading on pressure washers and am ready to buy one for this spring. I believe that an electric washer will be sufficient for the cleaning needs I have (deck/windows/car). I was seeing a lot of threads about the AR 383 which seemed like a good washer, except for how annoying it can be to outfit a foam cannon (MTM Hydro) with it. Thankfully, it sounds like buying an adaptor that is now available from AR fixes that problem.
AR 383 1900psi 1.5GPM from Amazon has the washer for $163
Amazon.com: AR Blue Clean AR383 1,900 PSI 1.5 GPM 14 Amp Electric Pressure Washer with Hose Reel: Patio, Lawn & Garden
I also saw a Cleanforce washer mentioned from Home Depot which appears to have more universal fittings which would be easier to hook up a foam cannon to. There seems to be quite a few more unfavorable reviews on this washer and it is a weaker washer.
Cleanforce 1800psi 1.5GPM from Home Depot for $169
Cleanforce 1800 psi 1.5 GPM Axial Cam Heavy-Duty Electric Pressure Washer-CF1800HD at The Home Depot
I have also heard general bad reviews of the Karcher units so I was thinking of staying away from them.
Are these the two washers I should be looking into or is there a better washer that I have not come across in these threads?
The new Karcher X series are the best out there.
AR is good.
You may want to spring for a good gas powered unit. They're $299 from Home Depot.
I was looking a the Home Depot 1800 because we got a sale ad today. Some of the reviews online are pretty negative. I may look at the Karcher X series. I just don't like all of the proprietary connections. You have to buy all accessories from them. Right?
I have the cleanforce and I like it. You don't have to get any special fittings to use a foam cannon. The major plus for me was the fact that the hose and power cord reel into the unit. Since I'm mobile it makes it so much easier to haul around.
Sent from my LG-VM701 using AG Online
I bought Karcher HD 6 / 15C, electric pressure washer.
2800 PSI
2.6 Gallons per minute
Powerfull, and handy for almost anything, a really nice tool for a car wash.
I connect it to my Foam cannon HP bought from autogeek.
With the karcher x does the suction kit for a static water source work with this model?
I've seen the karcher model with the induction kit. Just looking for some clarification as the suction kit is sold on it's own as well.
So people are saying the Karcher X series is the best, but I am wondering why?
The Karcher is $249 vs $160 for the AR
They both have stupid proprietary connections.
The Karcher is only 1800 psi (for the $249 model) where the AR is 1900.
What makes the Karcher the best value choice when it costs $90 more and has these same downfalls?
Sent from my Nexus 4 using Tapatalk 2
The new X series has very high quality internals.
First water cooled motor in the league. The X series has an induction motor which is much better than the universal motor of the AR. They both have high quality pumps, but the Karchers is better. The X series is a higher quality unit internally.
So do the ones that don't have this fancy motor only last 6 months or so? Makes me want to just buy the Costco one for $139 and return it when it breaks if these cheaper motors are that much worse.
Dan,
The AR is a very good unit, don't get me wrong. They have a good warranty, too. Buy it! :dblthumb2:
i use a greenworks 1700 psi pressure washer i bought at lowes 2 years ago it works really well for the 165 i paid for it. its quiet and plenty powerful for automotive. it comes with quick connections like on a air hose and it comes with a soaker , 40degree,20degree 0degree and a 0 degree that spins so it covers ground quickly on heavier duty jobs. it has whees and a nice hose real which keeps everything tidy. its has dual tanks and when i wash my car i just put my dawn dish soap in both containers and switch the dial to the other container when the one i am using is empty. i also used it to clean my sidewalk driveway and siding. not the best by far but easily gets the job done for automotive. def alot better than the ones at the car wash. also its maintenance free. it your just getting one for around the house use dont worry about pressure as long as it is over 1500. i know when i first got mine i cleaned my 94 ranger with it and learned that the 20 degree nozzle at 3 feet away takes paint and pinstripping right off. thankfully that was my beater and i didnt care but i learned to only use the 40 degree nozzle for automotive stuff.
I'd definitely buy the AR unit over the Costco. It's only a few bucks more and it's much better. The universal motor that AR uses is pretty good.
My Karcher is a year old and holding up great! It was $129.99 from Walamart. I guess I can throw the box away because its officially out of warranty.
Now its not some crazy 3,000 psi / 3gpm pressure washer. But it gets the job done fine.
Even came with a "car cleaning kit". The little brushes are excellent:
You can use ANY accessory with a Karcher, you just need this little adapter:
AG sell them for $15. But, I've seen them on the Internet for as little as $3.
My set-up:
Some foam from this set-up:
This $129 pressure washer has worked flawlessly for a year. So, even if it broke today, I still got my money's worth out of it.
One thing I would do different next time, is I would buy a unit where you can "roll-up" the hose. Rolling up the hose is a real PIA.
It is a nice feature but on my pressure washer you have to wind it carefully (efficiently) otherwise it does not all fit. The hose is stiff and takes a little set when stored.
I used my AR already today and will be using it again here in a few mintues. I am happy that I bought it.
I just got all the stuff I needed to make my foam cannon work.
(Copy and Paste from my post in another thread)
I have the:
AR Blue Clean AR383 1,900 PSI 1.5 gpm
Briggs and Stratton 1/4 x 25' Hose
Briggs and Stratton Gun
MTM Foam Cannon
Powerwasher 80006 Quick Connect Kit
^^^ Bought Online - Amazon
1/4" Quick Connect tips set from Home Depot
Quick Connect Extension Wand
^^^ Bought local
You need all of this in order to make the AR Blue Clean work because of the hose and adapters that it comes with. Sure I could have paid $100 more and gotten a gas model but I have very little noise, no gas, no oil, no exhaust, and it stays ready to be used.
I don't use the hose reel. I just roll it up and lay it beside the washer, the cord also.
