In the context of using a pressure washer for detailing, I don’t see duty cycle as something that matters. In my use, my pressure washer pump isn’t in use for more than 3-5 minutes at most and that’s for the initial rinse or foam gun use before turning off.
If you were planning on using the pressure washer for driveways, decks, exterior house use, etc. then I could see duty cycle being important. But an electric pressure washer wouldn’t be something I would use for those purposes anyway.
Rereading the comments... It looked like 1 failure on the 2.0 (the original post). The other one mentioned was a VE51.I just wanted to double check MisterSnoop. Was it the old model or the new 2.0? I do know the first ones had problems!
Rereading the comments... It looked like 1 failure on the 2.0 (the original post). The other one mentioned was a VE51.![]()
