Favorite correction compound and polish duo?
DETAILROOKIE
Hello All,
I am new to paint correction and plan on testing out different products on a test hood that I plan on getting from a local body shop, but I wanted to get everyone's opinion on which correction duo gives them the best results. I've read a lot about 105/205, Wolfgang twins , and now Jescar, but which duo has given you the best results? Is there one that will work for any color?
Sent from my SAMSUNG-SM-G935A using Autogeekonline mobile app
Some good duos which I've used are.....
Boss Fast Correcting Cream and Perfecting Cream
Meguiar's Ultimate Compound and Ultimate Polish
I like
M100/M205.
Rupes Zephir/Keramik
Griot's Garage Fast Correcting Cream and Perfecting Cream are great. The newest bottle of Fast Correcting Cream that I have dusts way too much so I put a tiny bit of Perfecting Cream on the pad and it seems to reduce dusting by a bit.
HD Adapt and HD Speed when doing heavy correction (2-step). When I ran out of both of these products I'll try the new 3D AAT Combo.
M101/Optimum Polish II produced outstanding results while correcting my front bumper, earlier today.
Both are SMAT, so there is no need to "break down" the abrasives, but both products allow for long buffing cycles with just a spritz of water/QD. I used the M101 with a LC yellow flat pad and finished out hologram free and LSP-ready on my Makita, were I have chosen not to follow up with OP II on a crimson LC Hydrotech, and that is no exaggeration. The OP II took things to that "next level", so i'm glad I did.
Always thought OP II was a tremendously underrated product. I use it for wetsanding spot corrections down to 2000 grit and it performs flawlessly and quickly. In fact, i'm fairly certain it would be able to handle 1500 grit sanding marks as claimed, I just haven't had occasion to try. It has also performed wonderfully as a medium cut polish and as a fine/finishing polish.
Have also recently been experimenting with 3D's AAT (501/502) combo and have had great success, but the compound comes with a bit of a learning curve IMHO. Didn't seem to like temps below, say, 50 degrees. 502 does, indeed, finish out hologram-free on a rotary.
I like
M100/M205.
Wolfgang Uber Compound 3.0 with Wolfgang Finishing Glaze 3.0 using Smack Method. Note, Wolfgang is Menzerna refined/made for Autogeek.
I like the ones above. In addition to those, I also like the following combos:
D300 then M205.
Blackfire twins - SRC compound and finishing polish.
The boss creams have not failed in any situation so far and no dust
I'm going to sit back and watch and laugh at how many different bests you get :laughing::laughing::laughing::laughing::laughing:
Ad infinitum.......................................:doh:
Jescar and menzerna are one in the same
