I don't do rinseless, but I do quite a bit of waterless washing. For waterless I like UWW+ the best. It has great emulsification and buffs off really easy and streak free. Leaves a very high gloss shine and a slick feel behind.
As far as towels go, I use either the 16" X 16" 600 gsm Extra Fluffy Microfiber Detailing Cloth towel from Microfiber Tech or the 16" X 16" 700 gsm Extra Fluffy microfiber (also from Microfiber tech) for the washing phase.
I sought these towels out specifically because they are double-sided, meaning they have the same knapp on both sides. I feel this is important in waterless washing, because when you fold your towel in fours you will have 8 sides to work with per towel. With most regular mf's, you usually get a longer knapp on one side, and a shorter knapp on the other. So I found myself only using 4 sides of the regular towels instead of all 8, because I didn't want to use the short knapp side for waterless washing.
So with the towels I use now, problem solved. I do use a regular MF for the buffing / final wipe phase of the waterless wash though.
Hope that helps.
Hope that helps.
