First BOSS G21 detail 07 GT500
Even though I don't have my garage to work out of anymore I have still been getting requests to do corrections/details. So for now I will be doing a little mobile stuff. A few days after picking up my BOSS G21 setup I got a call from a client that wanted his 07 GT500 taken care of. Luckily he has a pretty sizable garage with good lighting. I figured this would be a good time to bust out the new G21, pads and polishes. On this particular car the fast correcting cream followed by there perfecting cream gave a awesome result and was very easy to use. Being that I mainly use Menzerna products these were just as easy if not a bit easier. And hardly and dusting witch is a nice plus! Aside from this being the first time using my G21 it was also my first go around with HD Poxy and boy did it not let me down!!!
Seeing as this was a mobile job I didn't have too much time for pics. But I did get a few good ones!
Washed with Meguiars gold class shampoo
Bugs removed with PB Bug Squash
Wheels cleaned with Iron-x, Tires cleaned with TuffShine tire cleaner
Wheels sealed with Hydro2, tires dressed with Blackfire Total Eclipse, wheel wells dressed with meguiars all season dressing
Paint Decon'd with Iron-x and fine nanoskin mitt
Paint polished with G21 BOSS fast correcting cream, BOSS white pad. Finished polished with BOSS 21, BOSS perfecting cream, BOSS yellow pad
Flex PE8 was also used in tight areas with the BOSS perfecting cream and Flex 2in/3in pads
Paint sealed with HD Poxy
Glass was also sealed with Hydro2
Plastic trim dressed with Meguiars aerosol plastic dressing
Upon arrival
Iron-X working on the vinyl stripes.
50/50 BOSS 21, Fast correcting cream, BOSS White pad speed 5
All done
Looks awesome! As for lining up the backing plate, I always set the tool down on the bench, place one or two washers on the hub (aligned) and visually line up the aluminum hub on the backing plate with the tool hub. Then just slowly set the plate on the hub. I'll wiggle the plate until it nests in and aligns. It takes a little practice... Please let me know if you've got any questions on the system. Try Griot's Garage Polywax via a GG6 and a Red Waxing Pad @ 3 next time. The durability will blow you away! Spread on a panel or two, then wipe off . No Dust. One Pass Wipe off.
Thanks for the suggestions! I did use my GG3 with a finishing pad to apply HD Poxy. Will definitely look into the the GG Polywax.
Beautiful Work! That Boss system is bad ass! Again, beautiful work and so cool to see the results of the Boss!
Thanks bud. Really impressed with the BOSS setup.
Nice work! Love his license plate! Haha
Thanks. Glad you caught that. Being a LS guy I do have a soft spot for a nice GT500. Especially since this one makes 600+ rwhp
