Bruno Soares
- Mar 30, 2017
- 2,482
- 2
Bilt Hamber 35 pct off for Black Friday.....you know where to find it
My order is in. Got a few more products since their sale is good on many items there.
Just grabbed the Surfex-HD since I have the No-Touch I have heard amazing reviews about it. I have really been looking for a really good APC mainly one I could use on interior. The price for 5 liters was hard to pass up!
I thought about trying that after I've used OPC. Surfex-HD looks impressive.
I received mine but haven't had a chance to try touch-less yet. I plan on using it mostly in a foam cannon, so I have to figure out how much to use based on that 4% PIR they recommend. I do have an iK foamer but wasn't really planning to use that for this, mine is the older version that you have to pump until your arms fall off and I have no compressor anyways to add a valve that makes this easier. So I mostly don't use that iK foamer.
You can also use BH AF in a sprayer. Works as well or better than foamer.
I use i think its 9 or so oz of touchless in 2 gallon garden sprayerAre you using the same dilution ratios with a sprayer?
How are you guys liking your touchless with BH. I used to import $$$ jugs from overseas with the many many threads over at DW.uk
Had subpar results.
I swore off importing said goods and while I have looked at the BH touchless many a times recently, I don't plan to spend many of pre-wash products anymore...
I swore off pre-washes or at least importing the good stuff
I'm just thinking the chemical-ology is just made for the water they have over there and not the water we got here ;-)
Had subpar results.
I used Touch-Less today for the first time. Car wasn’t too dirty so I did a 2% PIR using a PF22 foam cannon. After calculating the flow from my power washer, 2% PIR called for 7oz of soap in the cannon. 4% PIR would be 14oz. Looks like I’ll be using the 5L pretty quick.
I was impressed by the results. The foam running down made me see how the car wasn’t all that clean. And my driveway was dirty because the foam was brown as it ran down the asphalt.
After foaming I rinsed with deionized water and dried with my ego 765. Truly touchless
Only touching I did was to apply some tire dressing. Came out pretty good.
