Klasse Act
- Feb 21, 2012
- 27,833
- 2,943
I'd love to see them release a coating
Just ordered some touch-less, and was wondering a couple things:
a) does this strip any lsp (in particular ceramic coatings)?
b) safe for PPF?
c) anyone tinker with dilution ratios to make a waterless wash?
Much appreciate any input, and looking forward to using this. Thanks
I have always been the type to just add a few ounces of APC into my foam cannon along with whatever PH neutral soap I am using. Will Bilt Hamber Touchless noticeably out perform the PH neutral soap + APC combo?
This is the ratio I use in the winter time to melt away the muck BEFORE entering the touch-free wash, basically 5 oz of Bilt-Hamber and 1 gallon of distilled.Can't say for sure....as I've never combined a PH neutral soap and APC. I can only tell you that Touchless is a very solid product that delivers exactly what it says it will. I apply mine with an IK Foam Pro 12 at 25:1 ratio....stuff just flat out works
Yeah the foam cannon PIR seems to work out to 1:1.You will use more in a foam cannon since you'd fill that about halfway with soap vs a few ounces in a pump up foamer.
Briefing this thread. Is the choice of using a hand foaming pump more due to
-lack of PW
- choice of use for consumption of product
I have a battery operated hand sprayer and I could rig up a Tee Jet Foaming Nozzle and such but given the options, it's a whole lot faster just doing the foam cannon route
My only gripe with foaming is the shaving cream it leaves on the driveway but between the post wash and, much of it has either run off or at least got really diluted.
Are you using it in a foam gun or an IK Foam Pro 12? I use the latter because I don't have an air compressor and anywhere from 3-5 oz w/1 gallon of distilled water melts away dirt and or winter "muck". The foam cannon and that PIR ratio sounds confusing but to me it seems a 50/50 mix in the foam gun does the trick.I swore years ago I would never import any more detailing products from overseas.....
I've somewhat stuck to that....
Ha.
I also swore never to add more pre-foam to my stash, and I have quite a bit of 5L's jugs all about 60%+ full from my previous overseas foam acquirements...
I bit the bullter. I ordered Touchless and Auto Foam just to see what the futz all the chirping is about.
I have used Auto Foam a long time ago and wasn't impressed by it. Maybe it was reformulated. I dunno.
But too many positive reviews on this that I just have to have some on deck ready to soak and rinse off the pending winter grime
Bilt-Hamber Touchless and Auto-foam are the KEY to beating old man winter and resetting your paint during the other seasons
