Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
First Place for Worst Paint - 1942 Olds Extreme Makeover
Bar none, the paint on this car gets First Place for Worst Paint. I don't think I've ever worked on a car with worse paint.
If you think it looks bad in the pictures you should see it in person...
Here's my Test Spot
Process
Step 1: Compound 3 times using Meguiar's M100 with Lake Country 7.5" Wool Cutting Pad on Flex PE14 about 1200 RPMs
Step 2: Polish 1 time using Pinnacle Advanced Finishing Polish with Lake Country Yellow Foam Hybrid Light Polish using Flex 3401 on the 6.0 Speed Setting
Step 3: Machine wax using Blackfire Black Wax on the Griot's 3" Mini Polisher using a Rupes 4" White Foam Finishing Pad on about the 4.0 speed setting.
And yeah... when I was doing the compounding step I was pushing hard...
Here's my Test Spot
Process
