I got some more work done last night. Running out of daylight sucks. I wish I had a lighted garage of some sort; This type of work is just about impossible to do in the dark.
Again, the plan was to iron out the system in the test spot, and then move on and try to do the entire roof before dark. I got the test step done and it looked great, so I moved on to the whole roof. I didn't get good enough pictures of the test step, so I will post the other pictures I took when I started on the entire roof.
Here is a picture of the entire roof. In this picture, I have completed the testing on the part of the roof closest to me, wet sanded the light RIDS out with the 3000 grit trizact pad, and buffed again with about 5 section passes of Ultimate compound. The test section is no longer marked with tape, because at this point I had removed it and done the rest of the roof with about five section passes of Ultimate compound. I did do them in small sections, but I had chosen to do each compounding step entirely on each panel before moving to the next. I have wiped the entire panel here with IPA so I could see the true results.
After this, I took a good long hard look at each section of the roof, even the one I had already done (which was the test spot). I have basically divided it up into thirds, so there are three different sections. I found a few more small RIDS, so I sanded the small RIDS again with my trizact pad and moved across the whole roof.
Here is sanding after what I could reach from the driver's side.
And here is it finished after I had done the remaining roof area from the other side. I used a very bright light to pick the RIDS out, and simply wet sanded them until they were all gone.
The trizact pads are great. Much better than sandpaper ever was. The extra cusion in the pad makes them great for little touch up stuff like this. Again, I am simply amazed at how soft my clear is. It just doesn't seem normal for it to be as soft as it is. The RIDS were almost all very, very shallow. A couple of passes with the pad took care of most very quick. There were only a few that I had to hit several times before they disappeared.
After this sanding step was completed, I again buffed each of the thirds of the roof with about five section passes of Ultimate compund again, to clean up the rest of the paint and get the sanding hazing out. After this, the plan was to move on to a couple of section passes of TSR and then to a white pad with the Wolfgan polish, but it was just about dark. I took the little but of daylight I had left to do some inspection with my light. There was not enough daylight to do any good, so I was using my hand light. For those wondering, the light I am using is an LED helmet light that I built for riding mountian bikes at night, and it mounts on my helmet. It puts out about as much light as a car headlight, so it is more than enough to see the defects in the paint.
Looking at the roof, the Ultimate compund got about about 85% of everything out after this step, but I am still seeing a little bit of my scratches, and also just general swirling in the paint. It isn't much, but there is some there. It looks like very light cobweb swirls. In addition to that, I can still see holograms when I pull the light up and away from the surface. If I hold the light at about 2 feet from the surface and move back and forth, I can see them well. I am not sure if they were from the original hologram marks the car had or if they are something I am inducing. I was under the impression that a D/A was very unlikely to leave swirls, so I can't tell. I know there is a possibilty that the swirls induced by the hack detailers could be lower in the paint than what I am effectively working with my D/A, orange pad, and Ultimate compound.
I'm pretty confused at this point, but I will know more when I get home today. In the overhead sun, I should be able to see the whole story. One thing is apparent though, and that is even though the Ultimate compound is cutting, I obviously need something more aggressive than Ultimate compound. I think the consensus is that I can probably get all of the defects out with Ultimate compound, but I am going to have to do three times the work than what I would do if I were using M105. I'm going to do some calling around today, and try my best to locate a bottle of this stuff. If I can find it in the state, I'll likey drive to get it today or tomorrow.
I guess the number one question I have is this: Is it common to still see swirling after using Ultimate compound, and orange flat pad, and a D/A? At this point, I'm not sure if the defects are below the surface I am effectively touching, but it just seems to me that the Ultimate compound should be cleaning them up if they are near the surface. Since it is a MATS product, I'm thinking I should be seeing a near perfect finish when completed - one that will only be brought to a higher gloss once hit with the TSR and polish steps. After my first experience with the TSR, I don't think it will remove this swirling I'm seeing now if the Ultimate compound didn't get it out. .......In a nutshell, I'm beginning to wonder If I have leveled the surface enough tto get down to the defects that were originally there, which were the terrible holograms.
