Foaming doesn't make sense
Being the proud owner of a foam cannon (thanks to A-Train) an using it for a week on clients cars i would have to :iagree:all depends on the soap your using. I used CGW&G to strip before a correcting an it worked perfect. but also use megs hyper wash on maintenance washes an dosent seem to affect LSP (so far). So as i see it as long as you dont use a high dilution the soap shouldnt strip LSP
Yep that was a pic of the last car I did with it! Enjoy!
A-Train...what kind of foam lance is that?
Yeah I've seen it but for the price...I'm cool!
:whs: Thats why I asked because I have the MTM and I can't get it like this.
I read that thread. I'm sure it's good but for $80 more than an mtm hydro. I don't see a huge difference.
What soap are you using and how are you dialing the gun in?
I use chemicals guys CWG, optimum, and dura gloss. I just adjust the nozzle on the end to shoot a tighter pattern, you could also try putting in another oz of soap and not filling it all the way up. If I want it thick ill put two oz of soap and maybe 24-25 oz of water shake it up then fire away. I traded lsufan my old one, but just orders a new one bc I missed it.
I got the same one from Amazon Foam Lance 32oz bottle and CG Max Suds II,I haven't used yet because I had to get the right fittings for my Pressure washer.
I got the new fittings and put 2oz of Max Suds II and filled up the bottle with hot water and the results are great.Well I was testing so I foamed the ground,grass and trees :xyxthumbs:
But for less than half of the price you can't go wrong with the MTM cannon,very well made with brass ans stainless steal.
Autogeek asks for $120 ? Just because a sticker on the bottle ? If you buy the MTM from Amazon and 3 gallons of Max Suds II still cheaper than the AG Cannon itself.
Sounds like how I have things. I've been using CG Maxi-suds II, and it foams well, but the soap you're using in that pic foams even better. I'll have to give CWG a shot next time I need soap.
