fresh paint final polish getting spiderweb scratches ?
casey86cuda
Hi Everybody Im newbie here but been painting and polishing 25 years.The problem I'm having is when I do my final polish I use my brinkman led light you can see spiderwebs scratch like if you washed a car with dirt on it.The Clear I used was ppg 2021 frist time I have used this clear normal I use valspar or debeer.Im using 3m perfectit buffing system the clear called for 2 coat I put 3 on.I normal put 4 on.I made ths mistake letting owner by the paint & clear .The fenders I buffed iut look really smooth glassy inside my shop under floursent lights but if I put my Brinkmann swirlight on the fender you can se what I call spiderweb circle scratches.I have tryed several technics nothing works so any help or advice would be appreciate the help.Thanks Shawn
Check back in the other thread you started on the same subject. I've written some (hopefully) helpful suggestions in there.
