Eldorado2k
- Nov 9, 2015
- 14,583
- 729
Meguiars D151 PRC can be used with rotary. I don’t see why the other AIO’s shouldn’t be able to.Can a AIO be used with a rotary?
Seems appropriate with this thread so I'll ask here. Say one starts with least aggressive. Say white pad and a polish. If the correction isn't say to "satisfaction"... do folks up the product aggressiveness or pad aggressiveness first?
For example. White pad... M210... doesnt quite get it... so would one up it to orange pad... M210... Orange with M110... white with M110 or orange with M110?...
Not sure if this makes sense but was curious as to what others thoughts were...
Ryan
Sent from my SM-G965U using Autogeekonline mobile app
Ok. Thanks. That makes sense. For example. Tried 210 with white on this Redeye. Wasn't where I wanted so went to orange and 110 and perfect. Had to polish. Was just not quite as crisp as I like. Skipped orange and 210 but will try that in the future.Makes perfect sense. The answer is D). All of the above.
Only you can determine which combo works best.
Personally, if I really like a product (e.g. HD Speed or Griot's CC), I'll step up my pad aggressiveness first. JMO.
I get it is relative but I appreciate the feedback
Ryan
Polishing pads leave haze on my paint. I need finishing pads and ultrafine polish to get it perfect. I did a test spot with a yellow rupes pad and fine gel polish and that left haze compared to the white pad with the ultra fine polish.
It was most likely the polish, not the pad. Their fine polish does not finish well, unless the paint is hard. Rupes yellow pad will finish better than softer pads, IME.I did a test spot with a yellow rupes pad and fine gel polish polish.
