Rsurfer
- Jan 26, 2007
- 14,163
- 26
Re: Griots Random vs 7424xp
Here are a few rudimentary diagrams that will hopefully help you understand how the movement is created:
Here's a thread I found that was posted by Kevin Brown. He did an awesome job in explaining how a DA works. BTW there is no clutch in a DA.I'm guessing that the PC's clutch is similiar to the ones they (and many, many other manufacturers) feature in cordless drill/drivers: it reacts to resistance upon it's intended rotation.
If you've used a drill/driver to turn screws into soft wood then you know how this works. You set the turnable numbered collar (located just above the drill's chuck) to a low number and the drill will stop turning (and start clicking instead) in order to prevent the screw from being screwed too far into the wood. The harder the wood (or other surface you're driving the screw into) the higher the number you dial up on the clutch collar.
With the PC 7424XP they've pre-set the clutch to a predetermined resistance setting so that it's impossible to overly exert pressure and have the pad still continue to turn. This is what makes the tool safe and probably impossible to burn paint with.
