Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
GTechniq Tyre and Trim review by Mike Philips
First the technical stuff, here's what the GTechniq website has to say...
T1 Tyre and Trim has been formulated to keep your tyres and trim black and spotless for longer than ever. T1 also gives you ultimate control over gloss levels offering a natural satin finish with a single coat to a high gloss with multiple coats.
T1 is based on chemical nanotechnology designed to offer previously unattainable durability, hydrophobicity (water repellency) and oleophobicity (oil repellency)
Directions for use...
Thoroughly clean and dry tyres and trim prior to application
• Squeeze T1 onto a foam applicator, tyre swipe or cloth
• Spread evenly onto tyre and/or trim surfaces
• Remove excess product with a separate cloth
• For additional gloss, wait 10 minutes and repeat application steps
Here's my comments...
First - When this brand new car arrived the dealership had already applied something greasy and oily onto the tires. Somewhere I have a picture of my finger after swiping the tire sidewall and removing some of the black gunk.
So before I could even test out the GTechniq Tyre and Trim I had to thoroughly scrub the tires first to get whatever was on them off of them. And this is the key thing to learn,
First - Don't use caveman tire dressings on your tires, stick with quality brands like GTechniq.
Second - Before you can use any tire dressing the tires must be surgically clean in order for the product to properly adhere and to look good.
Here's the product in action!
So after scrubbing the tires clean and then washing and drying the car, it's time to apply the GTechniq Tyre and Trim. To do this I'm using a simple microfiber applicator pad which actually works quite well.
And here are the results... a very nice deep, dark satin finish...
I think Tom will be happy with the way his car looks on the outside and on the inside after getting a full GTechniq detail...
Final thoughts...
If you're like me and you don't like a greasy, oily tire and trim dressing then trust in the GTechniq name and try out their T1 Tire & Trim
On Autogeek.com
GTechniq T1 Tire & Trim 250 ml
GTechniq T1 Tire & Trim 1 Liter
Final thoughts...
On Autogeek.com
