Octopiston
- Mar 31, 2016
- 287
Depends on what kind of dyno and trans too.
I'll guess around the 570-580whp area with meth on a dynojet and auto. Lower with a really loose converter, add a little more for an M6. The heat (its summer), lower boost, stock heads, and a higher NA based compression ratio resulting in less timing are going to hold you back. Was the cam ground with going fi in mind or for an na set up?
