cleanfreak3
- Feb 24, 2014
- 157
What color of cyclo pads should I use with HD Speed? Also, does HD Speed remove clear coat or is it a cleaner?
Thanks!
Thanks!
Thanks!
This goes for all AIO:
The pad you choose is dependent on the paint. You want a pad that cuts the most but also finishes haze free. So you likely won't be able to get 95%+ or even 85%+ correction because you want a pad that also finishes without marring.
HD Speed has abrasives so it does remove clear coat.
From your edit question:
I would tape up anything that needs to be protected, and in regards to rubber trim that could be damaged whether or not the product stains it so I always tape it up. I haven't had a chance to use my bottle of Speed yet though so I can't say if it does or does not stain plastic.
HD Speed works awesome with Buff & Shine white and green pads.
Did you ever try it with orange?
CarPro orange?? I didn't know they made a orange pad or made colored pads like B and S or Lake Country. Do you have a link?
HD Speed is a wonderful AIO. Just recently did a black Honda Pilot and it turned out great
I've used white and tangerine lake country pads depending on the vehicleI'm going to do a black Honda Odyssey with HD Speed in about a month. What polisher/pad combo did you use?
