Hello all. I've been using this method for a couple small used car lots where I live for about a year now. I have a few questions for you all. I've been experimenting with some less expensive 3" sanding discs and just want some feedback from the group. I started with strictly 3M discs but then found some much cheaper. I just want to compare what others are using to see if the ones I am using are ok or if I need to go back to the 3M. The other problem that I've run into is newer headlamps that only have partial deterioration at the tops seem to be extremely hard to sand through the bottom part to remove all of the original coating. I've had to literally hand sand it dry with 60 grit paper and then go in with wet 280, 400, 800, 1500 and 3000. Can others offer any advice? This process takes me about 3 hours. Thanks for the help. Love the forum.
Aj
Simple. Don't take off all the "good" clearcoat. Take out the damage at the top of the lens, slightly overlapping from on grit to the next just to be sure not to leave any heavy scratches behind. When you get to the last step, such as 3000 grit... then hit the whole lens. Quick compound if you want, then hit it with the 50/50. Really, you shouldn't have to compound or polish if you are doing a clearcoat, if you take it down to 3000-4000.
btw, I very rarely go below 600g to start out. In fact, it's been a couple years... I had two really bad Impalas from Florida that had some weird coating on them, and I went to 360 or 400 to start. You should never have to bust out 220, let alone 60!!! :buffing:
I still prefer to polish it out and skip the "clearcoat" quite often when doing dealer work. Depends on the vehicle and extent of damage. In some cases, I just fix the top of the lens... blend it out and polish. End result looks very good and most of the lens still has good original CC
