Cougarstang
- Jul 14, 2009
- 4
Looks fantastic. I did a set about 6 months ago too, and they're holding up as well as your sister's
:applauseLongevity test- On going, 6 months after restoration
Here are some more recent pics of the headlight restoration I did about 6 months ago. Anyhow, the lighting sucks, so the pics are not the best. But, the headlights are still holding up with the spar urethane sealer. I live in Kansas, so we have a lot of temperature/weather changes, so in different climates the urethane may react differently. I will continue to update every three months if there is any interest.
What I would concerned with is the urethane yellowing. While they have some UV inhibitors, varnishes in general are very susceptible to yellowing from the sun.
I have no doubt that the urethane will fail. The question is, when will it fail? Every type of coating, whether it be wax, paint sealer, clear coat or the spar urethane will fail and the plastic light turn yellow and cloudy. Then it will have to be restored again or replaced.
On other forums, there have been discussions on this exact method. And many say it will never work because it was not made for plastic. Or that it will turn yellow or streak. Also they have said it cannot be removed from the light once its been cured.
My responses are:
Well, for a product that was not made for wood, it works pretty darn good so far. Maybe the Helmanns company needs to make a product for plastic lights. Then there would be no "controversey".
All lights, with any UV clear coat or sealer will fail, nothing lasts forever. If you got the money, buy new lights and maintain them regularly, and you may never have the "headlight failure" problems.
Also, this spar urethane can be removed after fully cured. I have tried it my self, it wet sands off fairly easily, then reapply the urethane and its as good as new.
This uv sealer has already outlasted the Klasse method I was using before.
Will the urethane last forever? NO
Will the urethane fail? YES
Will the urethane turn yellow? Probably, just as clear coat or any other coating you apply to the lights will fail and turn yellow.
As far as I know, I am one of the few doing this longevity test for the spar urethane, but I was informed that it has lasted as much as 2 years in the South. I would be happy with a year atleast.
Also, there is only one coat of the urethane when doing lights. When you apply it to wood, its layered and sanded in between coats.(according to the directions on the can) Also, its not mixed with mineral spirits when applied to wood like when you apply it to lights.(maybe I am wrong) So I dont know if the mineral spirits will take away any of the UV strength capability.
But, what I do know is it lasts for 6 months. I will continue with the longevity tests every 3 months.
Keep us updated....SEM products make a uv clear that comes in a rattle can that works well.
I am testing it out right know to see how it holds up. Will be adding this service in the spring if it works out.
I've been researching to find the best headlight sealant and one of the people I talked to pointed this out.
As he was giving me his sales pitch, he also pointed out that what he uses is permanent but is cured by UV exposure making it different than any other coating. He swears by it being superior to anything else. I have samples on the way and I will post up my thoughts after some testing.
When I say cured by UV rays, I mean it does not even harden at all until it is exposed to UV.
Nothing is permanent. UV rays destroy and degrade everything over time.
Ok, I see, it does sound like it would work well. Can you cure it with a UV light, or just direct sunlight? In windshield repair, we use small UV lights to cure the repair when sunlight is not available. If it works out, create a longevity thread for the sealant. Since it was made for lights, it probably will outlast the urethane. This thread is still ongoing with my longevity tests, and I think it will hit 9 months soon. It should last a year, and i have been told it will last over 2 years. I am not affiliated with any spar urethane companies, I am just learning this method and experimenting with it. It easily fits my current budget. For a product that was made just for wood, it seems to be working for plastic when mixed and applied correctly. If it turns out to be a dissappointment, I will then search for an alternative, so your opinions on your sealant is important.I say permanent to differentiate it from a sealant that needs to be re-applied like a paint sealant.
As far as being sandable, yes it is but the good thing about it is you can wipe it off if you made a mistake as long as your not exposing it to UV it doesn't harden.
What did you use for a uv source to cure it? How long did it take to cure? I have a couple of cans of the Sem Sealant and it looks to me like it requires a pretty high power source of UV. At $31.00 a can I really don't want to waste any of it.SEM products make a uv clear that comes in a rattle can that works well.
Hey Hotrod my trial of the spar urethane has been holding up as well. One light is urethane and one light is a headlight sealer/sample from my supplier. They look the same and it had been 7-8 months now and they have been pounded with alot of winter road salt. Definitely lasted longer than Wolfgang headlight sealant kit that i used previously. Also I have not put anything over the urethane like wax or re coat the urethane or anything like that......
