barkeater
- Mar 22, 2013
- 61
OK, likely everyone has moved on from this thread so I'll just post to keep myself amused
Finished sanding over the weekend and used mag plastic polish with da. Came out ok, but still a little hazy. I figured the spar would fill all that in. I am using the spray. Saturday was nice weather so figured I'd get a first coat. First one came out ok but noticed a few slight drip marks. Have some paint thinner/rag handy for just this kind of thing. Quickly put some thinner on rag and wiped off spar. Then noticed something odd.
It seemed that the paint thinner was causing the plastic to distort/melt. Aghh! Nothing terrible but not cool either. Did other headlight and it came out better. Set out to dry. After a few hours looked it over and didn't like the way it was coming out either so spent the night re-sanding both. This time I finished using swirl remover/da and that did much better job at getting the headlights clear. Fortunately the spots where the thinner melted the headlight is way up on the top edge which when installed is covered by the hood anyway.
Now the headlights are sanded and polished, and ready for coating, again. I went and bought some mineral spirits from HD. I assumed thinner and MS were same thing but apparently not.
I talked to a body repair guy whose doing some work on my car and asked him if they might be able to apply clear coat. He said that clear would melt the plastic and it would come out all cloudy and ruin the headlight.
I may spray a small amount of spar and add ms (1:1) and try the wipe method. Or I will retry just spraying and if it doesn't come out good just let it dry and sand/polish it.
At least all of the scratches are out of the covers
I'll post a pic tonight (pre-coating).
