Rhudeboye
- Mar 10, 2010
- 372
Before
icture:- My gawd, what a dump!
I’ll be using a light colored paint on the walls and would like to add a bit of contrast where the wall bumps out. I could use some suggestions on a color that pops.
Not sure what to do with the floor but I’m thinking of an Epoxy coating. Those stains are oil. I’ll be trying a chemical to lift it prior to applying the Epoxy.
What I’m working with for storage:
6 overhead cabinets Dimensions: 30 in W x 12 in D x 30 in H
2 short rolling 2 door cabs Dimensions: 28 in W x 25 in D x 34.5 in H
2 short rolling 3 drawer cabs Dimensions 28 in W x 25 in D x 34.5 in H
2 tall cabinets Dimensions 75X31
After buying 3 of these new, Lowes had a clearance on them and I stocked up. I even purchased what they had on display which is why you see the letters on the pivot door cab. All gardening equipment will be leaving the garage and going to a shed out back.
I’ll need Improved lighting as well. Currently when the hood creates a shadow when lifted so I cant get light in the engine bay.
I'll keep you guys up to date as I go along. phase one is paint and lighting.
