Klasse Act
- Feb 21, 2012
- 27,844
- 2,961
Look up 2 spots....^^^^What is BSD? I guess im not up on all the lingo yet?
I would suggest sticking with BSD for topping up PNS after washing, and for the product you can use “between” washes to clean up the rear bumper and trunk go with a waterless wash that does not leave anything behind.
I’d get a pump sprayer for this purpose and fill it with N-914 (or D114 if you have any) at the recommended waterless wash dilution ratio and spray it liberally. This will accomplish your objective of keeping the areas more prone to collecting dirt clean, while also not diminishing the characteristics of the PNS/BSD combination that you indicated you are happy with.
Recently started doing the same. 1 to 1 and it's super easy to use and still gives great protection and makes an inexpensive product even more affordable.I took Klasses advice a couple of months ago when I was having issues with BSD and it worked like a champ except I did mine at 1:1. I sprayed it directly on a lightly dampened MF towel too instead of on the panel, amazing results!
I don't use many pre made detailers but I can concur, this is a solid product.I'd give 303's Speed Detailer a try, a very quiet product that's really good
Off topic: Can I put a 2nd coat of PNS on a vehicle that I put PNS on a few days ago (no additional topper, yet (but will be BSD))? Not sure I got good enough coverage on the first pass and also winter-prep for Boston.
I’ve been mixing BSD and V07 50/50 for the last 3 months and have enjoyed it . Velvet like smoothness, not grabby at all. I’m using it over PNS
Do you have the same extreme water behavior and self cleaning ability from it with the BSD/ Chemical Guys V07?
Just saw this and would recommend you guys and gals who uses BSD to try this bottle EZ Mist Sprayer. I used it with apply drying aid and when applyied directly on the dry paint if you like that more than into the mf towel. Even if BSD is a thicker consistency it mist out perfect from it. The benefit with these QD that leaves high protection behind is that you don't need to be use 1 spray and try to spread it out over a whole panel. This leaves you with a very thin even layer of the BSD or any product really. And it's builds up a little pressure from it so even when you have triggered it it keeps misting out from it. You get used to it and is easy to work with.
EZ Mist Sprayer - Black
Here's one downside that you should carefully think of when useing it. Since the mist spray is almost atomizes be carefull or prefed to not use this bottle when it's windy outside. May seem silly but these products is not good to breath in. And also it's not good to get it in your eyes either. So get the knowledge on how the wind is coming and always have it in your back blowing when you use this. I have gotten it in my eyes the BSD and it's not pleasant experience at all. This is actually important with any spray bottle as some finer mist can come out from them too. But this you get more fine mist out of it. I love useing these fine mist spray bottle with the building up pressure in them as you spray it. Have another glossenhancer spray that comes original in a bottle like this.
Ad one in the next order and put your favorite QD/drying aid in the EZ Mist Sprayer and see how it works for you and how you like it. There are not anything close to this I think in how they works technically. Cut BSD 1:1 with distilled water if useing it as a drying aid and full strength if you apply it on dry paint for the long protection and if only a wipe down for maintance use the 1:1 dilution.
/ Tony
