Help needed - Diesel dust accumulation
lawrenceSA
Hi all
I am in desperate need of some advice.
A mate of mine has a VW Caddy panel van into which he has thrown a huge turbo.... now the problem is the huge amounts of diesel smoke pouring out the exhaust when under boost.
This in turn means that even after short drives, the rear of his white caddy turns black, and requires at least daily washing, and this obviously increases the risk of swirls etc.
We have cleaned up the back and coated with #845, hoping that he could then just hit it with a foam cannon and HP rinse it off, but this is not working as planned.
Is there any advice on a product that could help?
Thanks in advance
Id try Amazing Roll Off
Sent from my ADR6350 using Tapatalk 2
Iron X, clay, polish, Opti Coat.
Sounds like a good approach...
To the OP, if you're not aware, Opti-Coat II is an actual coating that you apply onto the paint. At a minimum this would put a barrier-film between the paint and the diesel film.
You can see Optii-Coat II in action here, note it was applied by first-timers...
1977 Can Am Corvette - Modeled by Amy and Janna - Pictures and Video!
I was a vague on my process. But to add some more, I would take lots of time on the decontamination process. If the diesel smoke is that bad you will want to make sure all that stuff is off the paint before you apply Opti Coat.
:postpics:
:hungry:
Well here are a few... will try get some more for you.
Thanks for all the advice guys....
Looks like I am going shopping for some Opti Coat:xyxthumbs:
...and here is what it looks like from the drivers POV when boosting... :bolt: You can see the smoke billowing out the back, and this is with an exhaust pointing straight down into the ground
