imranhakro
- May 7, 2012
- 142
To certain extent, usually I keep a bottle of Opti Clean and a clean MF in car at the trunk. Whenever there is bird poop, I will use it to wipe off ASAP.
The above mentioned ONR in the trunk idea is smart. OC/OG will protect against bird bombs better than any other coating as far as my research shows. There are numerous reports where the bird bomb outline showed initially but then faded after being exposed to the sun. I get them off quickly in my own case, so I've never had an outline left to test that situation.
OP->Thanks for following up and being your word! Even though OC's strength is in sheeting more than beading, I believe it's evident that the protection is still going strong!
Thats exactly what i do (in fact every detail geek does so). In my case i keep ONR at QD dilution in a detail spray bottle along with fresh MF always ready under the passenger side seat
