This is a portion of my e-book...
Word Definitions - Compounds, Polishes, Glazes, Paint Cleaners and Waxes
Excerpt...
Non-Abrasive Glaze or Pure Polish
Historically, the term glaze is used to describe a
bodyshop safe, hand-applied liquid used to fill-in and mask fine swirls while creating a deep, wet shine on fresh paint. It's a category of products used on fresh paint in body shop environments, which will
not seal the paint surface by depositing a long lasting sacrificial barrier coating using some type of protection ingredients.
A bodyshop safe glaze is used in place of a wax, sealant or coating because it won't interfere with the normal out-gassing process of fresh paint for the first 30 days of curing. The function of a bodyshop glaze is to hide rotary buffer swirls while giving the paint a uniform, just waxed appearance to ensure customer satisfaction. After 30 days cure time its normal to the seal the paint using a wax, paint sealant or coating.
Hiding Swirls
There's a number of reasons why historically body shops use a glaze on fresh paint to hide swirls. Most body shops are production oriented and perform a limited number of machine buffing steps due to time restrictions and profitability. This would include machine compounding with a wool pad and machine polishing with either a wool finishing pad or a foam polishing or finishing pad, both steps using rotary buffers.
The end results are normally excellent shine but with rotary buffer swirls in the paint, (also called holograms and/or rotary buffer trails), that can be seen in bright light. The glaze is normally hand-applied to fill-in and hide the swirls as hand application is fast and relatively effective as long as the swirls are shallow. This glazing procedure produces a finish that customers will accept at the time of vehicle pick-up. The results are somewhat misleading however because bodyshop glazes are water soluble and as such will wash off after a few car washes or repeated exposure to rainy weather and then the swirls will become visible. This is the standard and accepted practice in the body shop industry.
Note: Because there are no rules or regulations governing the definition or the use of the word glaze, manufactures and sellers of paint care products use the word glaze as a name for all types of products that are not true glazes in the historical sense of the word. Most common is the use of the word glaze in the name of a car wax or paint sealant.
I have some articles under
Articles on Car Paint in my
article list that talk about glazes too plus I think this article talks about them also...
The Secret to Removing Oxidation and Restoring a Show Car Finish to Antique Single Stage Paints
Excerpt...
#7 Sealer Reseal Glaze = Show Car Glaze
Here’s a photo of a few bottles of #7 from my car wax collection. I have some older bottles from before WWII, but this picture shows the transition from when the name changed from Sealer and Reseal Glaze to Show Car Glaze.
(Click
here for a larger picture)
The third bottle from the right shows the label during the transition when the name was changed. If you look closely under the words Show Car Glaze it reads,
(Same as Sealer and Reseal Glaze)
Transition Label Circa Late 1980's or 1990's
Just in case you don’t understand why there was some confusion over the use of the word "Sealer" here’s why; a paint
sealant is for
protection and should last through inclement weather and repeated car washings. #7 is water soluble; that means it will break down in inclement weather or with repeated washings. It offers no lasting characteristics. It’s not supposed to be a paint protectant, but a glaze that’s safe for use on fresh paint and will give paint a wet-look.
The name
sealer and reseal glaze came from it's ability to
hide or mask hairline scratches temporarily, or in other words it would
seal hairline scratches and as it wore off and was re-applied it would
reseal, or re-hide hairline scratches.
In todays detailing lingo
hairline scratches =
swirls.
#7 has no protection ability and no lasting ability. So when the word sealant became more commonly used in the car wax market
people were confusing the word sealer with sealant and purchasing and using the product thinking it was a paint sealant that would last for a long time and protect for a long time when in fact it's nickname is
Queen-For-The-Day, in that car guys would wipe their car down with #7 to give it the wet-look for the day of the big car show but the first time the car is washed the extremely wet look the product would impart to paint would disappear as the water soluble oils would wash off with the rinse water.
Anyway, the name was changed sometime in the early 1990’s as back in the 1980’s and continuing through to even today, a lot of “paint sealants" have been introduced in the car appearance market to compete along side Carnauba car waxes. So to avoid confusion the name was changed to reflect, (no pun intended), what this product is and has been famous for over the last century and that’s create a deep, wet shine on show cars.
Bringing the dead back to life...
Besides being used as described above, #7 is also famous for its ability to revive dead, oxidized single stage paints. This has to do with the unique
feeder-oil formula created by Frank Meguiar’s Jr. back in the early days of Meguiar’s which was also the early days of the Automobile. Meguiar’s was founded in 1901 and for perspective, only a few years earlier in 1886, Karl Benz was awarded a patent for a gas-fueled car and it wasn’t until 1908 that Henry Ford introduced the Model T.
I don’t know exactly when #7 was introduced but I think sometime in the early 1920’s, like 1923 or 1924. While #7 may have been introduced in the 1920’s, the formula that became #7 was around even earlier, possibly back to 1901. Here's a collection of 4 very old Mirror Bright polishes; it is my opinion that the formulas used in these products were pre-cursors to what became #7 Sealer and Reseal Glaze.
Photos Courtesy of MeguiarsOnline.com
Of course product like Menzerna Finishing Glaze, 3M Imperial Hand Glaze and Poorboy's Black Hole Glaze, are also examples of non-wax, non-abrasive pure polishes or
glazes.
