How many passes of WG PPE
WRXINXS
How many passes do you guys do when using Wolfgang Paint Polish Enhancer? I will be using a 4.5/5.0 speed setting on my PC7424XP.
Mike Phillips used 4-6 section passes in his review for the product does this seem about average.
How long do you let it haze. I hear it can be a bit difficult to remove if you let haze too long.
I will be using black LC flat pads.
Thanks,
Drew
IMO 6 passes is too much. If your using a Griots, I would do 3-4 passes on speed 4-4.5 with a grey CCS pad at the most. I've never used PPE by machine, but I've used P21S cleaner by machine and it starts to haze fast. There are no abrasives to break down.
Thanks guys and Swanic I have a PC so I guess I can still do the 3-4 passes but maybe a slightly higher speed like 4.5-5.0
WRXINXS; if you are using a PC7424XP, use speed 5-6 and about 4 passes, and wipe off while wet
you don't need a lot of pressure, you are just removing the old wax/sealant and prepping the surface for a fresh coat, so you just need to let the chemicals work rather than your weight
tip: if you do accidentally let the product dry, just put some new product over it and wipe off and it will remove the dried up product
