How much do you charge for a one-step exterior detail?
How many hours do you average for your one-step package?
if by myself between 2 -4 hours , if with help (1 or 2 guys) between 1-2hours , if i let the crew do it , around 2-4 hours.
** depends how much is to be taped , size of vehicle , how soiled , color....
Wow, that's really fast.
Hope this helps
In both of the pictures of the packages you offer you are doing a 2-step process.
Polish
Wax
A one-step process is where you use a one-step cleaner/wax which will clean, polish and wax in one step. Don't make no difference to me and thank you for sharing but just want to point this out for others so there's no confusion.
That's super fast but it can be done as long as you're working fast.
I'm fast when I detail. Here's the deal though, even if you're using a one-step cleaner/wax or AIO for you guys that don't like to type or don't know the difference, (there is no difference), when buffing out a car using a one-step cleaner/wax you buff the paint in the SAME WAY you would buff the paint if using a compound or a polish.
That is you use the product heavy or wet, or in other words, you use the AMPLE amount of product to get the job done. Assuming you're working on a neglected car, (thus the reason for a cleaner/wax not a finishing wax), you need a certain amount of liquid on the surface. This liquid, the cleaner/wax contains abrasives, cleaners, solvents (solvents can be water), and some form of protection, plus whatever ingredients are needed to simply keep everything in a uniform emulsion plus color and scent.
To work a section of a panel you would not only use the ample amount of product but you would still need to make some number of section passes. The weaker the tool the smaller the size of section you would work, the more powerful the tools the larger the section size you could work.
Taking all of the above into consideration, to adequately machine apply a one-step cleaner/wax to a neglected vehicle working section by section and making for arguments sake, at least 4 section passes per section, to buff out an average size car it would take me a minimum of 2 hours.
This doesn't include the waterless wash and claying the paint. And in most cases you want to clean and/or clean and dress the tires and also clean the outside of the glass.
A lot of factors involved, like the condition of the paint and even how dirty the vehicle is before you start.
Thanks for chiming in Cosmin.
I am not a pro, but my process for my own cars is similar to the one Mike describes. Neighbors asked how much to do their cars. I thought $200 would turn them off, but two of them went for it. Crap. Well, I view it as good exercise. BMW 3-series and Kia Forte.
Wash, including jambs, wheels, tires and wheel wells.
Clay, using mitt.
Iron-X wheels (I know, not worth the $, but I don't want to clay them and it brightens them up a bit).
Dress trim, wheels, wheel wells.
HD Speed using Flex 3401.
5 hours, $200. Could probably get it down to 4 hours, but I like fussing with the car the last hour. Two customers, $400/year income, and I probably own $2,000 worth of equipment and supplies. Don't follow my business model.
Don't forget the cost of doing the detail.
For me, that usually means 1 or 2 pads that will need to be replaced, about 4 ounces of product, cost of washing, and a little quick detailer spray or spray wax to finish the car along with some tire dressing.
On a job like that, I would estimate my product cost at around 25 US$. That is without a chemical decontamination using an iron remover. If you add that, it goes up an other 10$ to 20$ depending how much you use.
How to use a one-step cleaner/wax to maximize profits
Then if you go to post #56 - I posted what I charged in a reply to a guy that said what I did wasn't worth it. AT the time I replied to him he went by FivePoint.0
Post#56
And if you look at the date of the first post, (when I did the work), it was 2012 - 6 years ago.
That's the thread I was talking about. :)
Saw your post #56, and have to agree with you. Personally, I do see a place for one steps, cleaner waxes, AIOs, etc....Heck, even filler glazes have a spot.
Also read your post #60, where you said
In fact, in the first post of this thread I point out that too often people new to detailing get all caught up in doing a multiple step process, which takes a lot more time, to a mundane daily driver.
They make very little profit and it's the wrong service for this type of customer.
that is exactly what happened to me. Granted, one of the first cars I did was in real bad shape. Compound, polish, then waxed. Outstanding results. In a follow up session about 2 years later, I used an AIO to achieve good results for a daily driver and a customer who was more about clean and shiny. Slightly less money, and WAY way less time /energy.
Match the service with the customer :)
Just looked at the competition on my area.
Most of them are charging anywhere from $50.00 - $75.00 for a cleaner wax at about three hours..
Polish + Wax is about $125.00
Compound adds $70.00 + depending on the size of the vehicle.
I'm over what they are charging, but perhaps not far enough....?
ok so, first off i DO NOT WASH, theres a lot of reasons behind this if you want to know i can tell you but i dont wash, so i ask the cars be washed within 3 days of me showing up to the job site. before i start i DO do a panel wipe down ( whats the differance right)
i use my GG6, 5 or 6 inch vented plate
normally a orange LC flat pad
speed 4-4.5
3-4 passes
now this is were i differ a bit, since im going to wipe off anyways even if it was an AIO, i wipe off with PNS, so i spray my towel with PNS and then wipe off my polish.
i average 2-2.5 hrs for a sedan. and start prices at $200
to date ive only had 1... yes 1 person be bothered by the washing thing
speed 4-4.5
3-4 passes
But don’t your business cards say “Cruz’s Car Wash”? What’s the dealio?
yes they do, and im actually looking to re-brand its just a hard choice to make after having had teh name for so many years now. like i said though the washing has not been an issue at all as people come to me for the reason of a polish and im established myself as a very good one.
long story short, it was a witch unt to shut me down multiple times, local comp was calling inspectors to check out my stuff, making sure i was by the book, etc. while ive always been GTG it was getting out of hand, i mean i was even getting set up. a detailer would set up a job wait for me to start and then BOOM someone shows up to insp me. the last big one was waste managment over my waste stream etc. so in the end i made a "peace" offering you could say with the county and im gtg go now. this was also the push for me to try and be able to detail from home and why im going through to get that sorted out and legally approved.
It’s upsetting to hear your story. People just want to make noise for no reason.
Dan Tran
The Buffing Moose Detailing
I'm confused as to why you would need replace pads? What is occurring that they are being damaged to the point of needing replaced?
I think he justeans swapping to new ones, I use one pad per panel on all jobs
Sent from my Pixel 2 XL using Tapatalk
All pads have a working life. I think he is factoring that into the cost, and passing the eventual pad failure on to the customer. Which is smart.
eventually but I get years out of mine.
This is the best post I’ve seen in awhile. I’m just curious of experience and cost of living from some of you for reference? I’ve seen prices range from $120-$500 base.
I live in a area where the average price for a 3br & 2bth house is $120k and my base price for a coupe is $175 with Menzerna 3in1.
$125,000.00 - $200,000 ish in my neighborhood.
My Option 1 is $125.00.
Jax Kar Wash charges $59.00 for a similar type of service.
Jeez.......
Out here on the tip of LI, the average price of a small home has become $400,000. 3BR, 2BR? An easy $600k.
Yet, there seems to be zero market here. (All NYC or Jersey that come out to tour/live among the vineyards/wineries).
They spend a ton on landscaping, but zero on their rides.
Man! Crazy! Try Southern California 3Bd 2 Bth home median price is $750K San Fran is even worse $1 Million!
Yup, my grand parents home in Union City which they got for 80k in the 70s is now 1.2m
