Removing a bra can be a real pain. Has to be done warm, either in sunlight or with a hair dryer. Then you'll need 3M Adhesive remover to get off the left over adhesive. Then a full correction.
Why does it have to be done warm?
This is my method, I don't use steam, sunlight or a hair dryer. Just the way it comes into the shop.
Removing them is really easy. Lift at one corner and start pulling towards your body, away from the car. That way the adhesive stays on the backing, instead of on the car. Pull every piece off this way, do not fold it over and try pulling over the 3M.
This is tough to explain in words.
But you can have an entire Hood/Fender/Mirror kit and Bumper kit off in 5 minutes. Then if you see any remaining adhesive, take a lint free rag, not a microfiber, pour a cap full of solvent on to the rag and gently wipe over the adhesive until it's gone.
Then rinse the area with a water bottle or quick detailer.
I charge $50 for removal on a HFMB
If they're concerned about the line between fresh paint where the 3M previously was and the old haggared paint around it, now is the time to upsell a cut and polish service and 3M re-application at your regular rate :xyxthumbs:
I do them every day. Most of my work is 3M install and removal. Maybe I can take a video and show you how haha
Super duper easy.
If you pull it the wrong way you'll get the adhesive stuck to the car. Change your technique and I'd bet you'll notice better results.
Chatelaine,
Are there variablse in how the film was applied or between manufactures that would cause some films to be more prone to leaving the adhesive behind, regardless of how you peel it off? Seems there are so many detailers that have horror stories in dealing with them that it makes you wonder if that may be the case.
I've also heard of several instances where it lifted the paint too.
This video is how my installer told me to remove the film. Doesn't look like the adhesive stuck to the paint here. I've only done it a few times now but out of them only one came off without leaving any adeasive behind...which makes me think there is possibly another variable to this???
I really want to try it pulling off the film the other way but I have Opti-Coat on my car now so I may just wait.
[URL="http://www.youtube.com/watch?v=OQ6Rg6yd_PA] - Honda clear bra removal[/URL]
This is a LITTLE off subject but, I was wondering especially from Chatelaine if there is a way to help maintain the clear bra...like how we polish and wax paint to keep it in good shape...is there a way to keep the clear bra in good condition?
I dont personally have one but I run into customers with them. The other thing ive noticed, especially on darker colored cars, is a color difference between what part the clear bra coveres and the paint right next to it. Can anything be done about that or is that one of those 'it is what it is' deals?
