terriusvette
- Jul 18, 2015
- 42
Hey guys. any tips on how to properly clean the dust build up in the door way. Its easy to clean the majority of the debree but how do u get deep in those crevices...
Are you talking about the door jambs?Hey guys. any tips on how to properly clean the dust build up in the door way. Its easy to clean the majority of the debree but how do u get deep in those crevices...
For me the process is usually to HP rinse, spray some APC through a foaming trigger head on a normal spray bottle, let it dwell a bit then begin agitating with various brushes. I will typically use a little boars hair brush and the Daytona Jnr. Then HP rinse and dry with a blower.
Then later in the detail I use Autofinesse Tripple, which is an AIO that IME has some pretty decent chemical cleaners in it. I work it in with a MF applicator pad, let is sit on there while I continue with other parts of the detail and typically only then buff it off the following day (but it could be buffed off after a few minutes I am sure).
\For me the process is usually to HP rinse, spray some APC through a foaming trigger head on a normal spray bottle, let it dwell a bit then begin agitating with various brushes. I will typically use a little boars hair brush and the Daytona Jnr. Then HP rinse and dry with a blower.
How do you get the jambs clean with a HP rinse without getting water in the vehicle? Is there an invisible wall they have for sale?!![]()
