Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
- Thread starter
- #41
Here's the write-up for the work done...
Before & After - 1961 Plymouth Fury Barn Find
Here's the process used....
Process
Step 1 - Chemically decontaminate the car
I used a modified technique for Iron X because I wanted to make sure any iron contamination is removed. I sprayed down the body panels with Iron X starting with horizontal panels first and then after they were rinsed clean I moved onto the vertical panels only tackling one side at a time.
Step 2 - Wash car using DP Waterless Auto Wash
For this I used a super heavy saturation with LOTS of clean microfiber towels to liquefy the Iron X and wipe it plus any and all dirt off the body panels.
Step 3 - Mechanically decontaminate the paint
For this we used the Porter Cable 7424XP with Nanoskin Autoscrub Pads (Medium Grade) and Detailer's Pro Series Universal Clay Lube
Step 4 - Compound paint using SONAX CUTMAX
For this step we used the SONAX CUTMAX with the Flex 3401 on Speed 6 with 6.5" Lake Country Hybrid Orange Cutting Pads.
Step 5 - Machine polish and wax using SONAX PAINT CLEANER HYBRID NPT
Next we used the SONAX PAINT CLEANER which is not technically a dedicated paint cleaner but a hi-tech cleaner/sealant.
A cleaner/sealant is like a cleaner/wax in that it will clean, polish and protect in one step only instead of using some type of natural wax ingredient for protection it uses some type of synthetic ingredients for protection.
Rob McCrary at SONAX USA told me that the SONAX PAINT CLEANER had the cutting ability of SONAX Profiline Nano Polish. So this should remove any haze left by the aggressive compounding step while leaving the paint clear, glossy, rich in color and also protected.
For the exterior glass, chrome and stainless steel trim I simply ran over these surfaces using the orange Hybrid cutting pad with the SONAX CUTMAX.
Hubcaps and tires were wiped clean using an all purpose cleaner.
Now who came closest to describing the above?
How about a few guys read through this thread and lets come up with a winner!
:xyxthumbs:
Process
:xyxthumbs:
