i am AUTOS E63 AMG
Thanks Mike! You should!!
As far as the floor it's the race deck FreeFlow (I got it from momentum industrial coatings - local company, but I think AG sells it) so all the water drains nice, but it takes a lot of water to wash the grit and dirt to the drain. So typically I wait a few days for it to dry, then shop vac it out. For cleaning it, I use one of those Costco nylon car wash brushes and scrub it.
Lol it's warmed up! We were right around freezing, it was -30 C the week before... Balmy out!
Again thanks for the kind words guys!! Appreciate it!
Great job. How is the cut and finish of master compound?
In my personal experience & also what I have heard from others. All of the polishangel polishes are extremely compliant to what the user is trying to achieve. polishangel uses abrasives that are not found in other polishes & have one of the longest work times of anything I have used. A combination I haven't tried yet personally is the polishangel Lambswool pad with Master Compound. I have been told the cut & finish of that combination can exceed a microfiber pad with decent compound on many paint types. Plus the Lambswool pad is a very tough construction and may never delaminate like microfiber. Another tester says that on soft porsche paint he was able to achieve 85% correction after dialing it in. Obviously that will not be typical results but is possible.
Plus they smell Amazing!
-Travis
Master Compound is my favourite compound. Cuts like IS1500-FG400, but finishes out like FF3000-SF4000. Zero Dusting, smells great!
This is MC on the Master Compound cutting pad on the Rupes 15. (100% correction wasn't required, customer want like 75-85%)
Here's another Master Compound 50/50
RUPES LHR15 with Meg's MF pad.
All of the amazing threads I've seen from you two using PolishAngel products has me sold. Really looking forward to using them in the spring on my current Jeep and to using them on my new Jeep in the fall. Really would love to see how the color matched Cosmic looks on black paint.
Thanks for the kind words!
It looks pretty wild! A good friend of mine is going to do 4 layers on his black SRT4 Caliber come spring. Definitely sharing that detail.
4 coats. :xyxthumbs: looking forward to seeing that.
Cosmic has some great beading properties with one coat. However, it seems each additional coat can greatly increase that, more so than other products I have tried layering.
