BlackCoupe
- Apr 23, 2006
- 525
My concern is that I can not get my surface swirl-free. Black, soft clear. I have never been able to get it perfect. It can LOOK perfect after Menzerna Micro Polish with a grey or green pad, but when I clean it with alcohol, there are always fine swirls remaining. I tested a small area, and I was hoping that Opti-Coat would fill these fine swirls, but that does not appear to be the case. (Although I should say that the swirls seem to be dulled a little, as though the "sharp" edges have been softened?). Once I put on Opti-Coat, they are locked in.
Perhaps I should go a bit heavier with the Opti-Coat? Or try a second coat? I know a better solution would be to get the finish swirl-free, but that does not appear to be in the cards.
