I'm pretty confident there will be a noticeable difference. :dblthumb2: Not to take anything away from OPC @ 3:1, but for soiled stuff, use it straight!
:iagree: That's pretty much exactly how I use OPC as well.
I'm confused here. You state OPC is weak yet is good for greasy parts like under the hood? Talk about contradiction my friend. A great thing about OPC is that it's not a caustic cleaner.
I absolutely love this stuff. I am an instant fan of it. I have used it diluted and undiluted, however I don't think I diluted it correctly. I did three parts OPC and 1 part water. I'm thinking its the other way around...am I wrong? Either way it goes, I need a gallon of this stuff PRONTO.
I prefer OPC too (I have 4-5 APCs in my collection) as it has the broadest range of uses. I tried to save money by buying a gallon of APC+ for $15 instead of a gallon of OPC for $35. I can make a whole lot of diluted APC+ for $15; however APC+ mainly sits in my cabinet taking up space and I still need a gallon of OPC. :doh:
I asked Chris Thomas from Optimum to respond regarding how to dilute OPC.
From a chemist's standpoint, a 33% (v/v) solution would be described as a 1:3 dilution meaning 1 part in a total of 3 parts, or 1 part chemical solution plus 2 parts solvent (such as water). A 1:3 dilution does not mean 1 part to 3 parts from a chemist's standpoint.
For interests sake, a 1:1 dilution is the undiluted chemical in its initial concentration (100% v/v) alone. A 1:2 dilution is a 50% solution made from 1 part straight liquid chemical plus 1 part solvent.
I'm not sure what OPT really means by a 3:1 dilution:
A) 1 part OPC plus 3 parts water (25% (v/v))
B) 3 parts OPC plus 1 part water (75% (v/v))
C) 1 part OPC plus 2 parts water (33% (v/v))
If you diluted 3 parts OPC with 1 part water, you made a 75% (v/v) aqueous solution, which I don't think is what OPT intended as it would only offer a 25% increase in working volume.
If you dilute 1 part OPC plus 3 parts water you actually make a 1:4 dilution from a chemist's standpoint. Certainly a cost effective dilution if appropriate.
I may be making it up incorrectly but I have been using a 33% solution (1:3 dilution) with is 1 part OPC plus 2 parts water, which works pretty well on the interior and light grime. I will often start with 1:3 dilution then move to full strength if it doesn't work.
I tend to use it full strength for wheels, tires, engine bay, door jams, and the run off gutters around the trunk and roof line on some vehicles. I'll use it 1:3 on rubber moldings and window trim to remove oxidation from the rubber before treating it with a dressing.
Let's see what Chris says about the proper dilution method.
We definately went to different schools. Lemme ask you how you make a 1:1 dilution then! One part OPC and zero parts water???????
Check this out and it may help you.
http://www.autogeekonline.net/forum/product-charts-graphs/31925-dilution-ratios-32oz-bottles.html
The single unit is always the chemical 3:1(3 parts water for every 1 part OPC). For example: to make 32oz @ 3:1 you divide 32oz by 4 total parts (3+1) to determine that each part is 8oz. So your mixture will be 8oz OPC with 24oz of water.
It does get a bit confusing. Some bottles have the dilution ratios right on them which is helpful.
After reading this thread I now know how to read the bottle lol!!!
