Pats300zx
Active member
- Mar 7, 2006
- 5,332
- 21
Was just going to post this but you beat me to it. Can't beat it for $10.
Nothing within 50 miles![]()
Tried almost all of Florida.
Edit: Arcadia has two. Hour and a half, can't make that drive until the weekend.
They will hold them for you and you can pay online or in the store when you pick them up
Is this blower really worth getting into blow drying cars with? My local sears has 5 so I can run down and get it and be back in 10 minutes, but I am worried would I really use it? It says it blows at 180MPH, but can you really dry a car that way, or does the speed die down really fast, or spread out so wide it doesn't work?
Thanks
Thanks
Thanks
Thanks
Only problem is I might end up spending more on gas than it's worth. A 3 hour drive to save $30, a tank of gas could cost as much.
Picked one up. Cheapest I've seen for a new leaf blower with a good name.
I've heard a lot of people on here use them and being 9 amp it should work just fine. I'm assuming also since other use it it won't spread too much with having such a narrow tip. It's also electric so it won't die down.
I drove to a sears 40 minutes away, 30 miles. I get 36 mpg but I'd spend up to $20 in gas for it and get it for $30 if I wanted to drive somewhere. Otherwise they sell for $40 msrp.
I picked mine up yesterday for anyone who wants to know. Two pieces, the blower and the hose attachment. The hose slides on and has a sping loaded push lock button system to keep it on. Pretty standard. The blower is a heavy duty plasticy rubber material. Feel solid. Pretty small overall and not too heavy like another one I have. Should be good as long as it blows, especially for the $10-$20 (gas).
Otherwise if it doesn't I'll just put it on craigslist or use it to guick sweep the driveway or garage.
The Sears website is saying that leaf blower is currently unavailable now. First it said it was $30, now unavailable. I was going to pick it up yesterday but they were closed due to weather.
