Just posting my observation here - a full liter for any car seems like an awful lot to me, at least IME, although the OP did state it was used on wheels too.
Anyway, I'm wondering if I'm not using enough now - I get at least 3 - 4 applications out of a liter.
Interesting thread...
I just looked at my first post and no where did I say its a must have. I said dont underestimate what it can do for you and tried to explain the advantages. If you dont think you have a use for it, thats fine. Some vehicles are more prone to iron and industrial fallout than others. The fact is iron gets on every vehicle, some more than others and once its on your vehicle it continues to grow into the layers of your paint. Claying will remove most of whats there but if its deep into your paint clay cant get all of it. Iron X or Trix (whichever you decide to use) will remove all aspects of the iron, including whats embedded.i am glad you like this item, but i'm responding to the must have part of the first post. i have never found a reason to buy this sort of stuff for use on my personal vehicles. i think if i was a pro or doing other people's vehicles anymore, maybe i'd look into something like this for an initial decon but to use it on a consistent basis on personal vehicles is interesting. if the car was clayed and corrected...then protected, esp. with coating, i don't know how many times down the line i'd ever even need to use something like this. i can't think of a time with my own cars where the end result of any process has disappointed me and i've been like "damn, i wish i had the color changing decon chemicals."
along the lines of color changing stuff (though a different product/application), i remember when the Sonax wheel cleaner came out and i got some because people were hot for it. i never even finished the first bottle because i found that the Power Clean (at varying solution strengths) and regular wash techniques i've used for years worked wonderfully and at a dramatic cost savings vs. the fancy stuff.
That may be a better way of doing it than the way I do it because you can concentrate on one panel at a time and not use so much. I like to hit my whole car with it real good all at once and then use my power washer so its easier for me that way.Is it bad to do a few panels at s time. Spray iron x on a few panels, let sit for 5 minutes then hose off. Go to next few panels.
Thats my method but again its not the only method. For the most part the only caveat is to not allow it to dry and I advise anyone to read the product instructions first. How much you use and which method you spray it on is up to you. I also use a microfiber sponge to lightly agitate stubborn areas but that is also not needed either. Its just how I go about using the product.
I need to use it because of my location near tracks and heavy industry. It works. I also use it because its a major time saver. My mindset is that its easier to use this and get as much contamination off before claying so I dont have to rub on my paint so hard killing my arms.
Like I said I dont get paid to advertise for CarPro so if you dont want to use it I respect that and dont want people to think its a must have item. Its another product that can help the process.
Don't not have this in your arsenal
i was responding to
which is another way of saying "must have", but with double negatives in the sentence haha.
sounds like it works very well for you. i'm glad i'm not in a situation where i'd have to use such an expensive product often to clean my personal vehicles, i guess that's my main point. you should look into a legit coating if you don't have one, which will help fight contamination in a major way and cut down on your need to use this product as much.
