Does ironx cause marring/swirls? Feed back please. :buffing:
It may cause swirls in your nose.
Nope, Iron x itself does not cause any swirling of scratching.
Can it take the place of claying ... Since claying does cause
swirls/marring. Feed back please. :buffing:
what tundra said. What I have learned on what process to take is, wash, clay and then iron x(due to certain areas the clay cant get to) rewash and then wala nice and clean and move one to whatever next step you need to take
Just a comment....
I personally wash, de-tar, then iron-x and only then clay. My reasons are that I first want to remove the tar as these deposits are usually bigger in size than the iron deposits, so they may actually cover up some of the iron deposits.
With the tar out the way, I then iron-x to remove the iron deposits. This way you are not loading up your clay bar with hard iron deposits that could actually lead to marring.
Then all you are left with is contamination that is not tar or iron and thus claying will be quicker and easier and your clay bar will not become as quickly loaded up with contaminants.
Great point of view guys, thank you for the feedback. I dont have Iron x and might add it to the cart lol and give it a try. Question is this used only to do paint corrections like mentioned before, or do you agree to use it as a regular wash but going above a regular carwash for max shine etc?
