FUNX650
- Dec 1, 2010
- 21,057
- 1
Is/Was: Wet Glaze 2.0 capable of chemically stripping sealants?
Sorry I left the Prima product-line out of the equation.That would presume some indisputable evidence and agreement on what can strip sealants, and whether 1) those ingredients are present in WG2.0 in the right proportion, and 2) other ingredients in WG2.0 don't affect the result.
In any case, Amigo is unique in that it (according to Prima) can serve as a paint cleaner and a glaze and a polish, to varying degrees (affected by the pad choice and application method). Duly noted that you have expressed doubts about these sorts of claims from any product which brands itself in that paint cleaner category.
In consideration of the above, the Wet Glaze was somewhat redundant atop Amigo and complicates any assessment of the result. It would either need to completely remove all traces of Amigo, or need to happily coexist with it. I doubt anyone has indisputable data on that, either way.
Prima Amigo (again according to Prima) will strip Prima's sealants such as Epic, and also provide a base that improves the bond of a Prima sealant applied at the next step. It's unknown whether any or all that applies to Prima Amigo followed by products from other manufacturers.
I've been very pleased with the results and longevity of Prima Amigo followed by Epic, and periodically refreshed with Prima Hydro. Beats me, if Prima's claims of what the products do and how they do it are 100% accurate, but I sure like the result and that's the important thing.
I didn't realize it was going to have be any specific sealant that needed to be addressed during this particular:
"Is it possible to chemically strip sealants" discussion.
Duly noted that you say you like the results you achieve using Prima products.
