Issues w/ breaking down polish (XP)
I went to Mike Philips class back in 2011, if you haven't had a chance to go, you should, very informative and shows you how to do it all.
Anyway, my last polish (4 months ago) I finally did the whole car the correct way thanks to mike and everything came out good. Last weekend I don't know what happened, I had to stop polishing after achieving only a small section of the hood. I washed it thoroughly and sprayed the car down with Griot's paint prep.
After, I prepped the car for polish and started on a corner of the hood. I used Menzerna FG 400 as polish and right after my second pass no polish on the hood at all, it all disappeared. Let me stress, everything is being done correctly! New LC 5.5 inch flat foam pads. My speed was at 6 and the pressure on the XP was correct.
After this happened, I re-applied more polish and the same thing happened again. I then proceeded with Meguiar's M205 to seal, after that it looked awful. I had to use alot of force to wipe off. Any input please. BMW135i
Here are some pics:
Here are some pics:
