Excuse my ignorance, but with wet sanding - do you actually sand the clear down to the paint, or there is some clear left after the sanding?!
Thanks
What you are doing is leveling the paint you've applied. The goal is to remove as little of the surrounding area as you can. Let me know if I need to explain that more.Excuse my ignorance, but with wet sanding - do you actually sand the clear down to the paint, or there is some clear left after the sanding?!
Thanks
I'm glad this got bumped because it's a great guide, Richy! This is such a great skill to have, and I'm thankful for the time you took to prepare this informative guide. Your customers can move on with their lives as though the damage had never occurred, and they get to keep their otherwise intact factory paint to boot! Not only that, you've given your customers something that they didn't have before: confidence that if something like this were to happen again in the future, they'll know where to go to have the damage repaired.
I feel a lot better about tackling this sort of thing in the future. Thank You :xyxthumbs:
:caflag::urtheman::caflag:
I have a keyed van. My wife's. Worse -she just bought it. I only own a PC 7424. If I tried this, would that be enough to buff out the sanding? Secondly - how hard is it to wet-sand? What's the amount of force required? Motion?
I know I just recently saw a post where someone polished out 3K sanding marks with the Meg's mf system. Let the paint dry for days. Then sand, then compound.
For that car, I did a one step with DG swirl remover for the rest of it. 105/205 were just used in the repair area.It looks fantastic, You are really providing a service with your posts. Keep it up......Thanks
Now when you used m105/205 did you just do the panels you wet sanded or the whole car. And are you using the same spray gun for thr permanon and the opti.
Thanks again
Mike Phillips said:Nice how-to and write-up Richy,
