Use 2 coats of SG as a standard! U will love it.
You are ABSOLUTELY correct...just got my second coat of KSG
last week. That second coat was like night and day! UNBELIEVABLE!! ������
Any trick for the sg? Can you remove with onr? I have both but I dread the sg because its a pain to remove
KSG is very easy to work with when you know the tips and tricks but yes, you can use rinseless to remove stubborn KSG....BUT if you follow these tips and tricks you'll LOVE KSG:
-get a bowl of water
-get yourself a small spray bottle, say 4 oz or so
-square mf applicator pad
-the KSG, ofcoarse
Take the square mf applicator and dunk it into the bowl of waterN wring out so its NOT dripping but rather just damp. Pour the KSG into the small spray bottle. Grab the damp mf applicator and spray 1-2 sprays onto the pad and work into the section your working on, work it in left to right, up and down, don't be afraid. Then, REMOVE RIGHT AWAY, no need for it to set up, its acrylic afterall. It should be VERY easy to remove with a couple wipes and flips of your mf removal towel. Then repeat so on and so fourth.
Once done the car should look awesome but to get an even better look apply the 2nd coat 12 hrs later. If you drive the car after the 1st coat a simple QD wipedown should be fine or you could do a wash of your choice and then apply the 2nd coat. Not sure why but that 2nd coat really pops, time and time again I'm always blown away with the 2nd coat. Wanna add more after that because of how easy KSG is to apply and remove, GO FOR IT!
Oh yeah, one more thing, keep the applicator damp by dunking and wringing out every other section or so, doesn't hurt, you'll know when to do this after a couple sections. Lastly, DO NOT USE ON GLASS! Its a PITA to remove no matter what techique, use KAIO on glass for a nice coat of protection.
Hope this helps you and anyone else out, Klasse is an awesome product!
Yes...I would think a QD like sonus acrylic spritz
would be ok to use in between that second coat.
